RE: Plane caught on fire...What to do???
What brand of esc and how many amps was it? A prop strike shouldn't short an esc unless it was a really cheap brand and/or under amped.
If the hole is the only damage you can glue some popsicle sticks or carbon fiber inside across the hole to reinforce the fuse and cut a piece of foam to glue in the hole, add some light weight spackle, sand and paint.
