RE: DRONE 29S
well guys Swapped every piston/liner combo . a no go, made up a tiny amount of fuel and dyed it bright red to check for leaks around head and back plate not a trace, flat out low compression, will scout around and see if we can come up p/l s. on removing head the cutaway in top of piston perfect alignment with passage slot in liner martin
