RE: ST G20 15D
The first pic looks like the big end broke off the rod. Then the crank pin came out of the crank.
Did the big end bearing fail? and then the crank pin dislodged?
or was it a simpler case of the crank pin coming loose?
Either way I'm sure you'll have it back circulating again quickly.
Greg
