RCU Forums - View Single Post - CG based on change in weight
Old 03-31-2013 | 08:41 PM
1320Fastback's Avatar
1320Fastback
Default RE: CG based on change in weight
The Center of Gravity remains in the same spot reguardless of how heavy the plane is.
CG is a formula based on certain dimensions of the wings and tail and so forth. The weight is not a factor.
Do what you have to to get the CG at the recommended spot. Adding or removing weight from the nose or tail.
