RE: CG based on change in weight
In other words, what affects CG is a change in weight in the nose or the tail. Overall changes in weight do not necessarily change the CG unless, as I said, the change took place in the nose or the tail. Then re-doing the balance with the old CG point is necessary by changing weight in the nose to compensate for changes in the tail and vice versa.
CGr.
