RCU Forums - View Single Post - CG based on change in weight
Old 04-01-2013 | 02:20 AM
jetmech05
Default RE: CG based on change in weight
1320 is correct CG is an aircraft set formula. Not weight set formula. I usually come in on the heavy side myself. Weight is your enemy can you lighten anything? Don't try to add weight to set CG until you have exhausted all possibilities moving components around inside the airplane
