RCU Forums - View Single Post - Performance Test: Turnigy SK3 2118-2250Kv, 17g, motor
Old 04-02-2013 | 10:08 AM
DrMotor
Default RE: Performance Test: Turnigy SK3 2118-2250Kv, 17g, motor
ORIGINAL: <span style="font-size: small">Dr Kiwi I've tested the Turnigy 2118, the Hyperion 1705 and the Infinite 1705</span>... maybe they are all from the same factory.
Hello Phil, Thanks for looking at this and also for commenting, and uploading your own motor test data.</p>
Phil: I DID mention the excellent test that you made in Oct 2011, of this same Turnigy SK3 2118-2250Kv motor, in post #4 of this thread.
The results that we each obtained for this motor, appear to be very similar indeed.</p>
However, I have just realised myself, that not only did you test this Turnigy 2118 motor, you ALSO tested the HYPERION Z1705-11T 2250 KV motor and also the OK Hobby Infinite A1705-2250 motor. As you know, these are both 11T motors with a 1705 stator, and therefore they would appear, in many respects, to be almost identical to the Turnigy SK3 2118-2250Kv motor.
-And of course we DO know that Hyperion, OKHobby Infinite, and Turnigy SK3 motors, are all made in the same Sunray Tech factory (see next post). Soin all likelihood, the Hyperion, Infinite, and SK31709 2250Kv motors are all actually exactly the same motor, justclothedin different color garments ....
-I will look at your data for the Hyperion and Infinite1705 motors in the next few days, and compare it the results I obtained for the Turnigy 2118 motor.
Thanks again, Phil</p>
