RCU Forums - View Single Post - Which chinese factories make various brushless motor brands?
Old 04-02-2013 | 09:10 PM
  #135
DrMotor
Default RE: Which chinese factories make various brushless motor brands?
<span style="font-size: medium">E-Flite motors -same as Himax / JP-Energ / TopModel X-Power motors</span></p>
The Turnigy G160 / E-Flite 160 -started me looking at a few other motors (always a bad idea ...)
-The E-Flite 160 is the same as the Turnigy G160 motor -already said that</p>
-AND: the X-Power XC 6332-16 motor -also has <span style="font-size: small">exactly</span> the same central plate on the rear housing (see pic 1) .... !</p>
In fact, the front housing of the X-Power motor looks very similar to the E-Flite / G motor (pic 2)
-and is also nearly identical with the HIMAX HC 6330 front housing (pic 5)</p>
and the X-Power 6332-16 motor is <u><span style="font-size: small">exactly</span></u> the same motor as the JP-Energ C 63-32 motor (pic 3)
And is also identical to the: HIMARK C 63-32-18 motor -from Model Engines, in Australia (pic 9)
AND: Also, the E-Flite / Turnigy G motor, <span style="font-size: x-small">has almostexactly the </span>same front appearance as a HIMAX HC 6330 motor (pics 4, 5)</p>
<span style="font-size: medium">SPOOKY ....
</span>
<span style="font-size: small">The reason that these motors are all so very similar ?
-E-Flite, Himax, JP-Energ, TopModel X-Power, and HiMarkmotors -are ALL made at the Himark Electronic Model factory (a.k.a. the ChinaHimark factory )
-Pics 7 &amp; 8 show some typical HiMark / ChinaHimark "C-Type" motors
Clearly, these are identical to E-Flite / Himax /JP-Energ / X-Power /HiMark motors
</span>
Pic 10 shows that the Chinahimark C 3526 motor,looks to be the very samemotor as the E-Flite Power 25 motor(shown in pic 11)
Pics show: 1, X-Power XC 6332, rear housing; 2, X-Power XC 6332, front housing; 3, JP-Energ C 63-32, front housing; 4, Turnigy G160, front housing; 5, HIMAX6330, front housing (the Himax 6332 is identical);6, E-Flite Power 160,front housing
7,Chinahimark C 6320 motor; 8,Chinahimark C 6332 motor
9,HIMARK C 63-32-18,260Kv motor -fromModel Engines, in Australia-THIS IS IDENTICAL TO X-POWER &amp; JP-ENERG MOTORS
And: Pic 10: Chinahimark C3526 motor-looks just the same asE-Flite Power 25 motor (pic 11); just has shaft coming out other side...</p>
ID:	1869644   Click image for larger version
ID:	1869645   Click image for larger version
ID:	1869646   Click image for larger version
ID:	1869647   Click image for larger version
ID:	1869648   Click image for larger version
ID:	1869649   Click image for larger version
ID:	1869650   Click image for larger version
ID:	1869652   Click image for larger version
ID:	1869653   Click image for larger version
DrMotor is offline
