RE: ATJ Turbines
Hi
I have now tested the new burner on a brand new ATJ-140SE, and on one of my old ATJ-170Ti wich had the old burner, but i shipped to ATJ for fitting the new ceramic burner. And what a difference! I tested them on a meeting on a frozen lake with temperatures at minus 7 degrees celcius. The burner works perfect, but in this cold weather i had to do some minor adjustments. I had to give both the pump and starter motor more power in the start menu. Other then that it worked great! The new 140SE was delivered with the new Zicoy ECU, V10. So the GSU is connected to the ECU with a JR plug, and not the "telephone cable".
So if anyone have problem with the old style burner, i would reccomend to ship the turbine to ATJ for fitting the new ceramic burner.
Christian
ATJ-dealer Norway
