RE: redcat monsoon front axles
The replacement CVD's that I last received from Redcat are an upgraded version from what comes stock. They've put a band around the universal to remedy the pin problem. They pop out of the cups usually when the wheels are fully turned on a rough hit or landing. The stock radio does not have end point adjustments so unfortunately if your still using it, this problem will likely continue until you limit the steering travel.
