RE: Starting issues
A simple thing is to make absolutely certain the fuel (shutoff) valve is plugged in correctly to the ECU. It is very easy to plug it in backwards or to the wrong port. I have seen this innumerable times. Might be one reason they are integrating the valves into the newer turbine designs!
