RCU Forums - View Single Post - Arming switch - advice.
Old 04-03-2013 | 09:43 PM
Anthony-RCU's Avatar
Anthony-RCU
Default RE: Arming switch - advice.
ORIGINAL: bem
-Would You say I would be crazy if I skip the arming switch and just unplug the batteries as unarming?
There is the canopy in my case that is screwed on/off so it would take maybe 10-15 sec to get the canopy off
to disconnect the battery. I really want to use a good arming switch so it is not that I do not want, but I want to be
comfortable with it and it must be bulletproof.
Bo</p>
No, I wouldn't say you are crazy not to use an arming switch. I have only recently experimented with one after years and don't really like it. I have throttle kill on my Tx that I use religously. It is checked before the batteries are plugged in and isn't switched until the plane is on the runway. It is flipped again when the wheels stop on landing. I do love a quick release canopy for the convenience of not having a ball driver in my pocket at all times.
I have seen a friends arming switch fail cutting off the main batteries. Luckily, since he was using a Ubec, catastrophe was avoided because of his back up system.
