RE: Starting issues
Thanks for the replies guys, I agree, best to check and double check all connections.
For reference if anyone ever uses this if they have the same issues, I ended up getting to the bottom of my problems.
It turned out that the turbine, since being back from an overhaul and an ECU upgrade had been set to propane start, this in turn limited the valves and the glow plug voltage and seemed to be the basis of my problems starting the engine.
