RCU Forums - View Single Post - ASTOUNDING NEWS RE DOLLAR STORE DEPRON
Old 04-04-2013 | 10:38 AM
drive2survive
My Feedback: (27)
Default ASTOUNDING NEWS RE DOLLAR STORE DEPRON
ok guys Ive been debuting about posting this but you guys need to know the big secret if you want some cheap foam models. Dollar store depron foam is the best and cheapest for your foamys
bar none!! Now heres the trick. Ive made many foam airplanes and I do mean many!!! when I 1st discovered dollar tree foam fought and tore my hair out getting the damn paper coating off! I had sprayed water on a sheet,soaked it in the bath tub for hrs and fought with the time consuming chore of trying to peel the paper off! Then noticed their was some dollar store stuff called AWSOME still left in the bottle I was spraying the foam with. This was the trick!!!!!!!!!!!!!!! so I sprayed the sheet with some straight awsome, waited 5 mins and the paper peeled right off. The chemical in the awsome must melt the glue holding the paper on as oppsed to just using plain water, now you know the trick go build some cheap models!
