RE: BOOMERANG ELAN - New Build & Setup Thread!
Ken
You should not have to put any more down elevator in when you reflex the ailerons, but be prepared for the aircraft to descend more than usual, it gives a much better rate of descent and you just control this with up elevator and throttle to your landing point, you should end up with the nose high, well not level, and the aircraft descending with about one third throttle applied, she is a real lady in this configuration and you should be able to put her exactly where you want, just adjusting the landing point with the throttle.
Mike
