RCU Forums - View Single Post - Pull/pull and CF pushrod questions
Old 04-06-2013 | 05:15 PM
Lnewqban's Avatar
Lnewqban
Default RE: Pull/pull and CF pushrod questions
ORIGINAL: CB36
Hi,
1) I'm installing a DHS pull/pull rudder in my RC Guys Decathelon. I've never done a p/p and not sure how you go about adjusting the cables after installing.
There will be threaded eyes on either end of the Kevlar cables and one end has a ball link, the other will go to a Hangar 9 swivel clevis horn on the rudder.
How do you get tension on the cables? I assume you can't just turn the threaded eyes, as this would twist the cables. Do you detach the ball link from the servo arm, adjust, and then reattach it?
Check these links out:
http://www.mindspring.com/~rellis2/rcpattrn/ppull.htm
http://www.espritmodel.com/pull-pull...planation.aspx
http://www.rcuniverse.com/forum/fb.asp?m=9227808
