RCU Forums - View Single Post - Kill switch question
Old 04-08-2013 | 05:12 AM
flyinwalenda's Avatar
flyinwalenda
Default RE: Kill switch question
For safety on the ground you should have a kill switch on the plane . For electronic ignitions that can simply be a battery switch that will make/break the ignition battery to the engine ignition. In addition to that you could add an optic switch so you can have engine kill in the air in the event of a throttle malfunction.
Yes that switch you have is used to ground a mag engine.
