ORIGINAL:
[email protected]
Hi guys. I'm still new and learning about gas engines. I have a DLE 20 and am not a fan of not being able to kill it without first catching it. I bought a cheap little GP servo operated kill switch and am unclear on something. So it only has two wires. The package says one to the engine for ground, and one to the ign. Ok, so do I put that wire in between the battery and engine. I figured as much, but wanted to be sure before I just went ahead and tried and burned something out. Thanks for any advise or tips, Steve.
If you have soldering skills you can use that switch. Just move the wire on the normall open contact over to the normally closed contact.
OR you can set up the servo to hold the switch button down for ignition on. I've always moved the wire.
CR
