RCU Forums - View Single Post - How much pitch control would elevons provide
Old 04-08-2013 | 03:10 PM
BMatthews's Avatar
BMatthews
Default RE: How much pitch control would elevons provide
ORIGINAL: nh4clo4
Just a thought, make the elevators elevons, Some smaller models do that to eliminate the weight and complexity of ailerons.....
That option really only works on models that are flying wings, deltas or use short span wings such as semi scale jet fighter style wings with wide spaced stabilizers. Otherwise the natural damping of the wings fight the roll effect from the elevons very strongly. In the case of the foam glider that AA5BY is using the roll authourity would more than likely be rather dismal as the wings are more than high enough an aspect ratio to fight the roll from tail surfaces and reduce the control effect to far below what would be acceptable.
