powerbox sensor switch temperature
I have just finished my 1/6 f16 and while range testing I noticed the sensor switch is getting a bit warm anyone else noticed it? I does say in the instructions that it can get to 60 degrees.
I used this same set up in a slightly smaller f15 but I was wondering if the longer leads to the elevator are the reason for it. I have a futaba 6014 with a orbit powerjack, sensor switch and two 2200mah 7.4v lipos, will it need a upgrade to a powerbox Gemini?
