RE: AMR Trainer 26
A couple of pics of the rear fuse sheeted with the hatch cover. The one pic shows the 1/4" dowel installed and drilled for the hold down screw. I also sanded and formed the trailing edges on the flaps tonight. Plus more filler and sanding on the top of the wings. Next step will be to mock up the ailerons and flaps with the hinges installed, on the wings and sand the trailing edges even. I also need to create a small fillet on the rear of the fuse and also on the battery hatch. I'm thinking a small blended curve will look better than a sharp angle. Also Aircraft World came thru this week and sent the new fan for the Hyperion motor that arrived damaged. Thanks Aircraft World! I've dealt with them in the past and have never had a problem. Their items are shipped from Japan and I feel arrive in a timely manner.lumpy
