RCU Forums - View Single Post - 18MZ Sequence Programming
Old 04-12-2013 | 02:25 AM
Philip Baum's Avatar
Philip Baum
Default RE: 18MZ Sequence Programming
Hi Mark,
unfortunately I did not find a manual for the TX. So I have to explain it. German would be easy but I try it in English:
- Fact it is absolutely simple
- FIRST - remove in the function menu the switches from both channels (gear and door)
- go to the program mixer menu
- select an off-set mixer
- define a switch for mixer-operation
- select for function 1 = gear
- select for function 2 = door
- find the right %value for the movements. If you operate with valve it is for both functions +/- 100%. If you use servos you have to adjust it
- in the area where you can select the time you have to test in which line you have to write a delay time. Fact is: always 1 way stays to 0
Normally it should work now......
Best regards
Philip
