RE: Undecided in which direction to mount engine
Thanks Bear,
So looking at the engine from the front with the plane sitting on it's gear, the glow plug is to the left? How far forward did you mount the fuel tank, was the rubber cap slighty through the firewall? Thanks for the tip on the landing gear. On Monday, I ordered the upgraded 3/16 gear from 'Robart'. Hopefully, they should perform better vs. the stock gear.
