RE: Do you use an electric starter?
In 55 years of diesel flying, I've never used an electric starter for any engine, diesel or glowplug. This includes such notorious engines as the Bambi, K Vulture and Drone diesels as well as Dooling 29 and McCoy 60 racing glows in speed models. I don't even own a starter. However, I have benefited from the use of electrics by others, since after the engine breaks I acquire it dirt cheap and simply make a new shaft, rod or whatever to get it going again!
A properly fitted diesel (and even many improperly fitted ones) should not require the use of a starter. If it does, there's something wrong (often a loose piston/cylinder fit or a base compression leak). And if you keep using a starter, sooner or later it will break. You may get lucky for a while, but it just takes one error in priming or choking.
There are also some engines which will be seriously damaged by a starter even if they don't break right away. The E.D. Bee and Hornet are cases in point - the only restraint upon rearward movement of the shaft in those models is the crankpin bearing upon the disc valve. Use a starter, and the disc valve will quickly be toast! There are many other examples ............
