RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 04-12-2013 | 11:36 AM
  #1165
Kenrico's Avatar
Kenrico
Default RE: Comp ARF BAE Hawk build thread
I didn't get Pic with it but the elevator trailing edge was way above the neutral you recommend after landing. If i rightly remember the top surface of the stab was below the break line,(probably why i had to pull so hard to get it off) by the time i landed i was almost out of trim travel on the Tx. some nose weight has been removed but the plane haven't flown since.
so would you say between 195 and 200mm i would still be "safe" for the Maiden?
