RCU Forums - View Single Post - wingtip vorticies
Old 09-19-2003 | 11:39 AM
  #42
Johng
Default RE: wingtip vorticies
OK, I went back and read thru the posts, and have figured out that I disagree with both Ken and banktoturn. [sm=eek.gif] The physical cause of induced drag is the pressure differential at the wing tip. This causes the vortex flow, with both spanwise flow and downwash being the result. Niether is the physical driver or cause of the phenomena.
Now on to the quotes:
When I refer to spanwise flow, I mean at or very near the surface of the wing. I think this is the most common usage of the term. Spanwise flow at the surface of the wing is not required for induced drag to occur.
I can't see the relevance of this distinction at all. OK, so say the surface layer of the air has "a boundary condition on the wing which precludes spanwise flow". So what? A molecues' distance above this you have spanewise flow, and all your condition might have done is increased the thickness of the boundary layer. That has no real effect on the spanwise flow of the mass of air being influenced by the wing.
I am not too concerned about a type of wing that cannot be built.
Hmm, better let the wind tunnels know. I've seen plenty of real 2d wings built for wind tunnels - that experience real aerodynamic forces. Plenty of lift, no tip vortex circulation, no induced drag.
Yes, reducing the tip vortex strength will reduce induced drag. The only problem with that is that you can't reduce the tip vortex strength without reducing lift.
That's just silly. Obviously you can reduce vortex strength to zero and maintain lift - as in the 2-d wind tunnel wing ( or airfoil to be techinically correct). Wingtip shapes are just an attempt to emulate this on aircraft. That wingtip shape will not necessarily reduce lift, in fact it will increase it if designed well. I have a design report somewhere on my bookshelf including the design of winglets onto a wing. The winglets were designed to both reduce induced drag and improve lift distribution - and thus overall lift of the wing at the same angle of attack. -Computed with CFD and proven in flight. Your statement would have me believe that the downwash and vortex strength are preserved in this case. I do not.
I've had enough. I'll leave further replies to others.
