ORIGINAL: MTK
ORIGINAL: Shimano
The prop hub conversion for the DLE35 is great, replacing the screwy screws from the prop shaft, making it a single prop nut assembly again.
I looked at one of those adapters but sent it back whenI realized it weighed twice what the 4 screws did
Ihadnt really considered the weight of it. Great point.
So at the moment you feel the OS 33 would be a better choice for a pattern application?
Iwonder, have you thought about installing Frank Bowman rings in the DLE 35? Maybe that might bump up the torque enough ot swing the bit larger props, and slow the speed down?
Maybe you have, and Imissed reading it.
