Waterproofing receivers using 3M 270 potting epoxy:
http://www.offshoreelectrics.com/pro...prod=ose-dp270
I use the lexan container and foam packing that the receiver came in to form container for setting receiver in the epoxy.
The epoxy easily releases from the lexan after curing.
I also epoxy in the leads for the servo, esc & bec (if needed).
I use a small piece of antenna tube (orange in picture) to seal the binding hole from the epoxy.
This tube is cut shorter and sealed with silicone after binding with transmitter.
Easy to remove silicone if need to re-bind at later date.
[/URL]
[/URL]
[/URL]
