RCU Forums - View Single Post - my first project foam trainer
Old 04-14-2013 | 10:14 PM
rockwusho
Default my first project foam trainer
hello everybody .. I am a beginner in the world of modeling .. and I want to make my own model ..So I started with a foam model ..This plan was designed by my friend that he is more experienced than me in modeling ..
at the first ,I don't decided to take pictures of the process .. butto avoid any mistakes ,I decided to take pictures of it here to consult with your. .
any way ..I draw your attention to the pictures whit any additional explanation!
<div></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div>
<div>
</div><div></div>i very tried that slices and cuts should be cleaned but this is first my own project (it amended at the future projects ) </div><div>
<br type="_moz" />
ok ..I used balsa beams with dimensions of 5mm x 5mm x 1meter to strengthen the wings
<div></div><div>
I used to make beams groove of the cutter 5 mm.
<div>
</div><div> </div><div>
</div></div><div>to be continue</div></div>
ID:	1872302   Click image for larger version
ID:	1872303   Click image for larger version
ID:	1872304   Click image for larger version
ID:	1872305   Click image for larger version
ID:	1872306   Click image for larger version
ID:	1872307   Click image for larger version
ID:	1872308   Click image for larger version
ID:	1872310   Click image for larger version
ID:	1872311   Click image for larger version
ID:	1872312   Click image for larger version
