RE: ESM Dornier DO 335
I had the same concern as VG about the threads of the bolt against the bushing. I think grinding down the threads gently and then wrapping it in tape should work fine. Ive used painters tape as a spacer before to get a wheel hub to fit an axle and it worked well without long term issue.
