RE: New Evolution Engines!! 15GX, 20GX, 33GX
As these bigger engines run a crankcase pressure system, will it be possible to mount the tank further backwards over the CG?
If it uses a check valve and crankcase pressure, there should be more then enough pressure to supply the carb with fuel as I see it.
