RCU Forums - View Single Post - Help soon ! Solder question?
Old 09-19-2003 | 02:26 PM
Rodney
Default RE: Help soon ! Solder question?
While silver bearing solder is somewhat stronger, I often use plain old rosin core electrical solder with no problems or failures over many years. As mentioned above, cleanliness is of paramont importance; and, yes flux is required for easy success. I shy away from acid core or acid flux due the the requirement for complete neutralization after soldering to preven rust and corrosion--difficult to accomplish. If you use a torch, be carefull, to much heat can be as detrimental as to little.
