ORIGINAL: flejter1
Aussie1,
I highly doubt you will ever have a problem with the kero plug going out. You will have more problems with burnt out glow plugs but everyone has there own flavors and tastes. The turbine would need a different internal wire harness installed and some kero start boards removed but it is possible to change it over if you really feel the need to have it done. I would still want you to send it to us for the upfit and ECU setting changes. That way we can test run the turbine and make sure it works properly. LIFE 9.9V works great with our Kero start turbine and has been the battery of choice among our customers. Like I said earlier, the 2S lipo will work but, you will be limited to fewer starts. I get calls from guys using the 2S on Kero start saying the turbine won't start and they need help. It always boils down to a depleated battery that is overlooked.
BTW,
Welcome to the KingTech family!!!
Yes, I am looking forward fitting the engine into my Panther, and kero start is also very appealing!
