RE: set up for obtaining more control surface travel
Try to make the adjustment on the control surface horn by moving the clevis in toward the surface as opposed to moving out all of the way on the servo arm.
When you move the clevis out on the servo arm you loose torque. The rated torque of the servo is measured as far in on the arm as possible and as you move out it gets weaker.
