RE: Which stick for flaps?
A70 You made some smart choices with the avalible transmitter. As you suspected and Flyinwalinda suggested the left side is the appropriate place and for the reason you stated so It can be carefully adjusted with the left hand. Are these the sliders that are between and a bit below the sticks that use to be a common location for channel 5 and 6 on very old units?
Exactly what is the Transmitter?
John
