RCU Forums - View Single Post - Tanaka 21cc conversion ?
Old 04-17-2013 | 06:35 AM
Deep Purple
Default RE: Tanaka 21cc conversion ?
ORIGINAL: w8ye
You need to change out the non resistor spark plug.
Most model engines had the NGK BPMR7F spark plug which is a taper seat spark plug much smaller than the one you have.
The tapered seat spark plug works perfectly in the hole originally made for a gasketed spark plug.
Thanks, i need all info i can get ....
( this is my first conversion )
How big prop for this one ?
I need a new carb, any tip ? the one on it have a 11mm hole
Ant tip for a prop adapter ? do it myself or buy where ?
