Hi Joe,
No. The Power 160 works fine. It swings a 19x10 APC prop and have tons of power. I just want to try a lower kv motor with a bigger prop to see if there is any difference in performance or flying characteristics.
Hi Arch, I looked at the firewall last night to see if I can mount the motor directly to the firewall. Yes the firewall is too thin. But the major problem is there is a plywood plate to stiffen the back of the firewall.
I cannot put the X mount behind the firewall or drill the holes because the plywood plate is on the way.
Another thread is just started by LD24 about the Monolog. He took some photos which show the firewall area.
http://www.rcuniverse.com/forum/fb.asp?m=11483564
