RE: Anyone EXTENDED their CEN GST? Check out this Chassis Kit....
Cool wider could be better, but keep in mind that the longer the wideners are the more stress you will put on the knuckles and arms which will cause more/faster wear! Not to mention easier breakage with the increased leverage longer wideners will create. But give it a try I am very curious to see if the suspension can take it.
oh and not trying to bust on ya but the measurement to determine the width of your vehicle is called Track Width not wheel base. Wheel base determines the length front to back, center line of front axle to the center line of rear axle. Just trying to help educate a little, sorry if it offends you.
