RCU Forums - View Single Post - Bad Virbration
Old 09-19-2003 | 08:22 PM
rod2_hi's Avatar
rod2_hi
Default RE: Bad Virbration
BTW,
You said earlier that you had a plastic spinner, then you went to an aluminum one and it still vibrates, don't forget to check the CG!!! You have added alot of weight way out front on the nose by doing that I would suspect, better safe.(also the balance of the spinner needs checked.)
If I can find the prop I balanced I will post a pic. It will show better than I can explain.
rod
