RE: ASM P-61 kit Build
It's going to be tough locating the ASM gear. I have been lucky not to have any problems with mine so far. There is some discussion on this thread about others who have used different gear that worked out for them. I set my Widow up running electrics with good success. I also have an ASM Invader that will be electric as well. I was able to find retracts for the Hanger 9 B-25 that I will tweak to use. Anyway, you should be able to find something that will work. If I remember right, I think thet were Spring Air. Good Luck. Ken
