RCU Forums - View Single Post - 2013 Bakersfield 2nd Annual Pattern Bash
Old 04-24-2013 | 01:17 PM
  #63
TonyF
My Feedback: (92)
Default RE: 2013 Bakersfield 2nd Annual Pattern Bash
Here is what Chip posted earlier,
Just one thing to add today.
The 35k Old School class will be 12 maneuvers not counting take off and landing, as is the 45k Masters class.
Also, he is using the 1983 FAI rules, not the 80,81 AMA as is the Classic Pattern Association. The K-Factors are different between 83 FAI and 81 AMA. Attached is a pdf with all the '83 FAI maneuvers. Also attached is a 35K pattern I did for Jamie.
Dale, while the maneuvers are a little easier, I think you electric guys are going to have problems getting through all 12 maneuvers along with TO and landing. The lower K maneuvers still take a lot of time.
Chip did mention a while back that he needs you to turn in your patterns by 10 AM Friday.
File Type: pdf
File Type: pdf
