RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Hi All,
I have an Aurora 9 and have a question around setting up split elevators. It's an Aeroworks Edge and I have 7955tg's on each half - each on its own channel (ie no Y lead) . I started by using my HFP-25 to reset the servos (plus open up the deadband to "2" - helps with the "jitters"). Mechanically the geometry of the linkages are good and I measure throws using an Angle pro. So, no actual problem setting up both high rate and low rate one each side to be perfect with a little use of the EPA. However when I switch back and forth from low to high rates both servos re-centre equivalently by a few degrees in unison. I have never noticed this before and if anyone had any suggestions as to what could be going on I would very much appreciate it.
best
Beej
