<span style="font-size: smaller;"> ORIGINAL: Beej Hi All,
I have an Aurora 9 and have a question around setting up split elevators. It's an Aeroworks Edge and I have 7955tg's on each half - each on its own channel (ie no Y lead) . I started by using my HFP-25 to reset the servos (plus open up the deadband to "2" - helps with the "jitters"). Mechanically the geometry of the linkages are good and I measure throws using an Angle pro. So, no actual problem setting up both high rate and low rate one each side to be perfect with a little use of the EPA. However when I switch back and forth from low to high rates both servos re-centre equivalently by a few degrees in unison. I have never noticed this before and if anyone had any suggestions as to what could be going on I would very much appreciate it. best Beej</span>
Please refer to:<a href="http://www.rcgroups.com/forums/showthread.php?t=498802">
. Digital Servo - Digital vs Analogue Hz, Deadband & Torque effects explained - Servomances</a><a href="http://www.rcgroups.com/forums/showpost.php?p=14939581&postcount=6">
. Digital Servo Instruction Videos - Programming with HFP-10, HFP-20, HPP-21+, HFP-25</a><a href="http://www.rcgroups.com/forums/showthread.php?p=13698540#post13698540"> ***
. Digital Servo Programming FAQ - Center & End Point - Adjust to Match TX</a><a href="http://www.rcuniverse.com/forum/m_10188213/tm.htm">
. Digital Servo Programming FAQ - Center Point May Vary - Why & Correction</a><a href="http://www.rcuniverse.com/forum/m_9859637/tm.htm">
. Digital Servo Programming FAQ - Center Point & End Point variance - Why & Correction</a><a href="http://www.rcuniverse.com/forum/fb.asp?m=10935389">
. Digital Servo Programming FAQ - Programmer is Preferable to using EPA & Trims on TX</a><a href="http://www.rcgroups.com/forums/showpost.php?p=18200025&postcount=4">
. Digital Servo - Burnout. Cause & Prevention</a>
and more under sub section:
"Servo - Digital & Brushless Servo, Programmers and Software"
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
