RCU Forums - View Single Post - Servo programmer issues
Old 04-25-2013 | 10:48 AM
grosbeak's Avatar
grosbeak
Default RE: Servo programmer issues
ORIGINAL: Gtarling
It's possible that a newer programmer won't recognize an older servo. If the programmer worked OK with your new(?) elevator servos, then I think this is the most likely answer. If you know anyone with an older programmer, it may be worth a try with that.
Two reasons why I don't think this is the issue:
1. It worked the first time
2. The HS-5625MG is listed as compatible with the programmer
Thanks for the suggestion, though!
