RCU Forums - View Single Post - Question on Wing build
Old 04-25-2013 | 02:49 PM
TonyBuilder's Avatar
TonyBuilder
Default RE: Question on Wing build
<span style="-webkit-tap-highlight-color: rgba(26, 26, 26, 0.292969); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); -webkit-text-size-adjust: auto; ">Once you get a few builds under your belt you will develop a build style. Recommended glues is just that. You can go with yellow glue instead of CA, or gorilla glue, epoxy or what ever you want. CA is a quick instant gratification but it is very brittle, it is ok for most soft balsa applications and tacking, but epoxy and yellow glue is much stronger and sands better to.</span><div style=" -webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); -webkit-text-size-adjust: auto; "></div><div style=" -webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); -webkit-text-size-adjust: auto; ">TB </div>
