ORIGINAL: roknHS
The Super Cub is very similiar to the 1/4 scale J3..........26cc to 50cc gas has been the range most used for gas power. My H9 J3 cub has a Brison 40 on the nose. Batteries are behind the back seat..........balances perfectly.........flies great.
My Super Cub is waiting for a DLE 55.........weighs about the same as the Brison. I put 1/3 scale cub tires on the gear.......just need to get the proper size music wire and make a longer axle..........I did it on my J3........works perfect.......looks fantastic.
Mine will be a sport flyer/glider tow plane.
I think most who want gas power will go with something like the DLE 30 or 35 for sport flying..............something bigger if you have higher aspirations.
I want to see how your cowl turns out with a 55. you better plan on figuring out how to make the prop hub that will stick out an inch and a half in front look decent.
