RE: HK-450GT CCPM Alloy T-Rex compatible - Part III
Hi guys,
Took the beast for a fly today at the oval and had some fun in FF. Did 6 packs, and it was starting to get dark by the 6th pack.
I am not sure if I like the LH gy520 gyro that much. There is a drift in it to the right. Tried to adjust the linkage rod and then adjusted the limits, but that did not work. There is also a bit of nodding in the cyclic during FF, that is, the tail bouncing up and down. This suggests a slightly bent main shaft as I cannot get the blades to track properly.
Other than that, towards the end of the day I was flying FF, then as I am turning, I climbed and did some piros, then came bak towards myself. So I was quite happy with that.
Sadly, the keychain cam had no juice left in it, and Im sorry about that.
