No, its a OS 110FS. If it were gas I would have used ball links- it would have come with ball lings in the first place
Actually, I didnt use the stock pushrods either. The ailerons are fill thread SS 4-40 Sullivan. The rudder and elevator are 4-40 one side threaded. The manual requires you to solder the other side, which I have never done, hence z-bends. I didnt use the 4-40 full threaded on the rudder and elevator as threaded pushrods have a lower cross section than one side threaded, so they are likely to fail earlier from corrosion. The clevis I have used are Dubro spring steel clevices
http://www3.towerhobbies.com/cgi-bin...?&I=LXD937&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXD885&P=7
Ameyam
