RCU Forums - View Single Post - Question on Wing build
Old 04-26-2013 | 12:19 PM
JollyPopper's Avatar
JollyPopper
Default RE: Question on Wing build
If you use CA, won't you need to have the wing halves clamped tightly together before applying the CA? I can't see dropping CA on the inner ribs and then trying to join the halves of the wing and get them perfectly aligned before the CA sets up. And if they are clamped together and you drop CA along the outer edges of the joint, how far will it penetrate toward the center of the ribs? I'm not saying that using CA is bad here. I'm just asking how far it will migrate and will that be far enough to get a really good joint.
