ORIGINAL: Kozzy_98
Hi guys, replaced the main shaft, checked that the blades were equally tight but there was still the same nodding, blades out of track and the tail drift.
I have a set of Blade Grips + feathering shaft + respective bearings/bolts etc. Would that help?
Hi Kozzy, what headspeed, motor and pinion are you running ? If your headspeed is too low it will cause a porpoise. With regards to the drift, have you setup your tail linkage so you get no drift in rate mode ? Normally once you do this, you can flick to heading hold and the tail should be solid.
Jonesy
